Re: 53 super m
Posted by Bob M on July 15, 2014 at 20:40:05 from (74.67.188.246):
In Reply to: 53 super m posted by Fank Rose on July 15, 2014 at 18:44:50:
As the others mention they all whine somewhat in road gear. That's just the nature of straight cut gears running at that speed.
What's likely making the whine is the differential ring/pinion mesh. (The final drive bull gears/pinions make a deeper rumble or growl at speed)
The noise WON'T be coming from the transmission - power is "straight through" in 5th (no tranny gears involved).
Using heavier gear lube (80W-90, or even 140) will quiet it some. Especially so if the old lube is the wrong grade or contains a lot of water.
