Re: Best Farmall tractor for chopping?
Posted by mkirsch on July 16, 2014 at 05:25:03 from (65.199.189.6):
In Reply to: Best Farmall tractor for chopping? posted by Fullern90 on July 15, 2014 at 15:38:23:
What is your ground like? Is it flat, or hilly?
To say that a Ford 5000 or an H would "struggle" with a Super 717 is the understatement of the century. I'm not sure they could run the chopper empty, let alone with any material moving through it, let alone trying to pull any sort of loaded wagon up any sort of hill.
Any of the >70HP 06-56-66-86 series tractors would be a fine choice for your operation. Just pick the one that's the best value for the money. 706-756-766-886 would be the bare minimum. 806-856-966-986 would be comfortable. Bigger is perfectly fine too, but you have to start watching the chopper instead of letting the tractor tell you that you're pushing too hard.
When you're farming, the saying "beggars can't be choosers" is the name of the game. Don't pass up on a smokin' hot deal on a sweet 1066 for example, because you think it's too big, or that you want some other specific model. Think targets of opportunity. Strike while the iron is hot. Have I used enough cliches to get my point across yet?
