Re: H Bolster
Posted by Tom A on December 29, 2000 at 13:38:48 from (64.40.66.173):
In Reply to: H Bolster posted by SheldonMT on December 27, 2000 at 19:56:05:
Sheldon: Getting 'em out is not too difficult. A good sharp metal cutting blade cuts through them pretty well. Just cut vertically and when all the way through, they'll clink out. As a novice I went through two sets of bushings, before I got it right, but it did cost me for the learning experience. Much like one of your other advisors suggested, I used a long 5/8 inch machine bolt to pull the top one down in its cavity. A large hard tempered washer or two on top, a 2 inch steel plumbing tee on bottom with a hole drilled through the horizontal part of the Tee to accomodate the opposite end of the machine bolt with washers and nut on the bottom. You'll have to make sure the washers are not soft, or they will be inclined to depress into the top of the bushing and flare it out....then it's a screwed up job and you'll have to start over. The bottom, well that's a toughy. I finally gave up and removed the bolster and turned it upside down on a 20 Ton Bench Press and pressed it in. The first time I hammered it part way in, laying on my back and ruined it. The bench press put it in smooth as butter. Use care, for they are very hard tempered iron and inclined to be a little brittle like saltine crackers. Remember to be sure line up the grease aperture with the zerk fitting canal in front of the bolster. Removing the bolster is not really all that tough and makes the job a whole lot simpler and easier on the parts. The whole secret, though, is by all means use some engine assembly lubricant on both surfaces, bushings and cavity walls. I tried the cold treatment, but by the time you get it in place it's expanded, especially when the bolster casting itself acts as a heat sink, then it's stuck half way in and half way out of the bolster cavity. GOOD LUCK! BE SAFE, that bolster is plenty beavy and a good hydraulic hoist comes in handy. Tom A.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
