Posted by Larry B. 1486 on July 16, 2014 at 12:43:28 from (72.105.171.170):
In Reply to: 986 leaking posted by 47farmallM on July 15, 2014 at 18:31:28:
The torsion shaft seals. Been there several times with my past IH tractors. Done exactly like Pete 23 said to do. Once they start to leak, it only gets worse.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
