Re: Super M belt pulley re bearing/re sealing questions
Posted by D Slater on July 16, 2014 at 17:42:57 from (184.14.196.209):
In Reply to: Super M belt pulley re bearing/re sealing questions posted by mike1972chev on July 16, 2014 at 07:59:21:
Take the pulley bearing and seal retainer bolts out next to the pulley flange. Pull shaft out keeping track of the shims. You can look at the shaft and see what needs done to change the seal.
Other shaft only has one bearing and a bushing.
Can get some idea of condition of it looking through the hole other shaft came out of. If you need to go farther the housing will not be as heavy when removing. Common for the bevel gears to give a rough feel when turning by hand.
