Re: 706D Low Oil Pressure
Posted by Notjustair on July 17, 2014 at 10:51:32 from (174.250.160.50):
In Reply to: 706D Low Oil Pressure posted by Montour PA Steve on July 17, 2014 at 08:26:40:
If there was significant wear on the mains I would have ground the crank. I would take the pan down and plastigauge it or mic the crank. I'd be willing to bet that the crank was ground 10 under years ago and they used the wrong bearings. You used ones that were too small as a result.
Was there any deep low main bearing rumble in the engine?
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
