Re: How do you fine tune a distributer?
Posted by David G on July 17, 2014 at 11:38:17 from (204.29.138.33):
In Reply to: How do you fine tune a distributer? posted by DeWayne Utrup on July 17, 2014 at 10:07:21:
You will get more power with the correct advance, and 30 degrees is right at the limit. The reason the idle was rough is that the curve starts early.
I would crank the total to about 25 and see how it runs. I am finding that I can run about 22 on my high compression engine.
