Hi, German Diesels have two common problems, first injection pump front seal leaking Diesel into crankcase and diluting crankcase oil, second was the O-rings on the bottom of the cylinder sleeves leaking coolant into the crankcase. Possibly sleeve cavitation allowing coolant into cylinder. Also a stuck or leaky injector can cause white smoke out the exhaust. Test for leaky O-rings, drain crankcase oil, leave drain plug out of crankcase and place clean container under drain plug, leave it sit for a day or more, check container for coolant.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
