Re: rpm increase super c
Posted by gene bender on July 18, 2014 at 02:28:49 from (67.55.226.121):
In Reply to: rpm increase super c posted by TennMatt1 on July 17, 2014 at 20:46:09:
There is a capscrew on top of the housing back it up some. Also remove the pin in the clevis going to the carb. With engine off open throttle then hold linkage linkage so the carb is open pin should go back in if not adjust that clevis. You will need to remove that piece so you can free up the clevis trying to adjust that clevis can bend the carb where the linkage pivots mite be able to use a vice grip on that linkage while you free th clevis. If you want more RPMS after backing the screw get a spring for a 240 they are stronger thus making more RPMs.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
