The other posts are on track. If there is antfreeze in the cooling system the white smoke will have a sweet "different" odor to it. (If water is the coolant, it will not have odor.) As mentioned,it is an indication of coolant into the combustion chamber. Head gaskets, cracked heads, or cracked sleeves can cause the issue. If it runs on 3 cylinders for a short time when started, it is surely that. After it sits over night, pull all plugs, leave the ignition off, and use the starter to spin the engine in neutral, no choke. Watch the sparkplug holes to see if coolant sprays out of one hole. Best of luck. Jim
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
