Re: hydraulic hose fitting leaks
Posted by mkirsch on July 18, 2014 at 12:08:07 from (65.199.189.6):
In Reply to: hydraulic hose fitting leaks posted by BigTone on July 18, 2014 at 11:54:02:
Every hose that doesn't terminate in a quick-coupler needs a swivel fitting on one end or the other. It's impossible to tighten the connections otherwise.
You can purchase just the swivel fitting to go between your hose and your pipe fittings. Just make sure to get the right type of thread, as there are three, and they don't seal up if you mix types.
Plain old galvanized/black pipe fittings are probably not the best choice, but people have been getting by with them for decades.
