Re: hydraulic hose fitting leaks
Posted by El Toro on July 18, 2014 at 17:15:29 from (96.244.7.206):
In Reply to: hydraulic hose fitting leaks posted by BigTone on July 18, 2014 at 11:54:02:
third party image
You should have hydraulic hoses made by your local
hydraulic shop using swivel nuts. I use JIC tube fittings and swivel nuts. The tube fittings are male pipe to male tube. Then connect the hose with the swivel nuts to the tube fittings. Take along one of hose's that has the pipe thread to get the correct pipe size on the tube fitting. I made these for my garden tractor using reusable fittings. Hal
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
