Posted by FBH44 on July 19, 2014 at 02:07:16 from (64.85.215.30):
In Reply to: W4 Brake axel seal posted by Olie on July 18, 2014 at 10:51:07:
If it is the same as "H", here"s my info on my "H" seals; Chicago Rawhide number, however they were not rawhide, just ordinary-looking metal seals with spring-loaded rubber tip-seal. Replaced all four CR seals. „X Chicago Rawhide # CR-541901-USA „X Case-IH CNH # 76510-C-91 [$22.10] „X NAPA¡¦s # SKF-23184. [$15.49] [ 3.500¡¨ OD, 2.313¡¨ ID ] Wound up as follows; Right Side = I damaged / bent the new CNH seal, so I followed it with a NAPA seal. [Drove the CNH seal in with a wood block, and bent the inner flange.] Left Side; I installed the CNH seal OK, but followed it with a new NAPA seal anyway. [Drove the NAPA seals in with a 3x2 PVC/DWV plumbing fitting.] Packed the seals with red wheel bearing grease before installation. TO INSTALL SEALS; Do not try to use rounded-off wood block. Seals are a tight press fit, and you cannot hit on the flange. Tap the seal into place with the white 3x2 PVC plumbing bushing fitting in ¡§H¡¨ box.
Today's Featured Article - A Lifetime of Farm Machinery - by Joe Michaels. I am a mechanical engineer by profession, specializing in powerplant work. I worked as a machinist and engine erector, with time spent overseas. I have always had a love for machinery, and an appreciation for farming and farm machinery. I was born and raised in Brooklyn, New York. Not a place one would associate with farms or farm machinery. I credit my parents for instilling a lot of good values, a respect for learning, a knowledge of various skills and a little knowledge of farming in me, amo
... [Read Article]
Latest Ad:
[More Ads]
