Re: Farmall Super A Timing - Odd Problem
Posted by gene bender on July 19, 2014 at 12:36:52 from (67.55.226.121):
In Reply to: Re: Farmall Super A Timing - Odd Problem posted by RTR on July 19, 2014 at 12:25:22:
I have the gears if you need them. You will need to pull the steering sector so the front cover will move enough to replace the cam gear. You can try without removing the steering housing but i dont think the front cover will move enough to pull the cam gear but its worth a try. Just get all the dots lined up when you go back together. for timing as the mag fires on TDC when cranking.
