Re: Farmall Super A Timing - Odd Problem
Posted by RTR on July 19, 2014 at 20:39:29 from (74.248.177.182):
In Reply to: Farmall Super A Timing - Odd Problem posted by Rich Iowa on July 19, 2014 at 10:19:28:
The gears on the crankshaft gear are all perfect......except for that gear being welded on! Also, I noticed where that weld on the gear to the crankshaft has broken loose.
What do you guys think the reason that the camshaft gear teeth are chipped and the governor teeth are SHEERED off? You think I should dig deeper and look at something else?
