Posted by farmallhal on July 20, 2014 at 10:21:38 from (76.2.170.208):
In Reply to: Super c engine oil posted by 53dc on July 20, 2014 at 07:54:35:
Congratulations to your dad for getting one of the handiest smaller tractors ever produced by IHC. I use my narrow front 1953 Super C fast hitch tractor to rake all of my yearly hay crop (6000 small square bales last year) and have found it to be the best rake tractor I've ever used. Of course a wide front won't have the same turning radius of the narrow front. With that fast hitch find some compatible fast hitch implements and you will wonder why anyone wanted those 3 point tractors in it's day. A lot of folks on this forum use 15W-40 diesel oil like Shell Rotella or Mobil Delvac in these older Farmalls which works very well. In addition to the rear end lube which the original operator's manual calls for SAE 90 weight you also have the Touch Control system which requires IH Hy-Tran or an equivalent which holds about 7 pints if drained. Also, the engine air cleaner has a cup on the bottom which uses about a pint of the same oil as used in the engine. An Operators Manual for the Super C will come in quite handy for the new tractor, Hal.
Today's Featured Article - Trailering Your Tractor - by Curtis Von Fange. One of the fun things of summer and fall are the parades and tractor shows that go on across America. Many owners of tractors travel long distances to attend these shows and they usually take their restored iron along with them. Safe trailering practices and inspections will ensure that the event is a fun one. A good habit to develop when using a trailer is to give that ‘quick look over’ before taking it on a trip. Before hooking up to it check the tongue for proper operation. The latche
... [Read Article]
Latest Ad:
[More Ads]
