Re: Oil for MD
Posted by FBH44 on July 20, 2014 at 21:13:07 from (64.85.214.238):
In Reply to: Oil for MD posted by n9lhm on July 20, 2014 at 17:02:45:
My understanding is there are two designations to check,
I understand that a spark-ignition engine ought to get the latest API code, which I bleieve is "SN". If you check on the back of the oil can, you ought to see a circular API rating, and I believe "SN" is the latest.
Similar, for compression-ignition, I believe the latest API designation is "CH-4", maybe "CG-4". You can check various cans and see the latest C-letter.
After you get the latest designation, then check about viscosity. For diesel, I"d use 10W-30. For extremely hot weather I"d use 15W-40.
