Re: Putting a c-153 engine in a super c
Posted by Rex Simpkins on July 21, 2014 at 15:43:33 from (69.251.237.110):
In Reply to: Putting a c-153 engine in a super c posted by TennMatt1 on July 20, 2014 at 22:15:51:
I am in the process right now, just waiting to get
some help to get front bolster on tractor. I think
I will have to remove some metal but I will know
soon and take pictures.
Back end is pretty straight forward you will need
a pilot bearing pressed into your original
flywheel-- I needed to cut 1 1/4" off of drive
shaft then bolt up simple.
Now for the front, you will see a few ways to do
this mentioned of this and other forums.
What I did---140 radiator and upper hose---140
themostat housing and radiator brace---140 fan--on
original 153 water pump. 140/240 lower radiator
elbow.
I will take so photos when I get the bolster back
on.
One thing I ran into today was the front fuel tank
support where it bolts to the back of the block on
the Super "C" the bolt holes are a little norrow
to use the support, so I had to drill it to make
it match the width 4 1/8" holes on the back of the
C-153.
Things have not gone to bad so far and it seems if
I throw enough money at it I can make it work but
it sure AIN'T BEEN CHEAP.
I am sure there are others who have done it other
ways and not had to spend so much, this one has
been hard on my wallet and easy on my brain.
