Re: 560 t/a
Posted by Janicholson on July 21, 2014 at 19:46:08 from (74.60.94.18):
In Reply to: 560 t/a posted by H66 on July 21, 2014 at 17:50:27:
The TA needs to be used under load for a while to assure it is not getting flat spots on the ramp and rollers. If it continues to slip, it will need that clutch replaced. (one way ramp and rollers) Jim
