Farmall Super M disk brakes - innner assembly with 5 ball...
Posted by andy r on July 22, 2014 at 06:17:37 from (75.91.149.15):
Farmall Super M disk brakes were rusted up. Dissassembled them sometime ago. When reassembling how do you know that the inner assembly with the 5 balls and three springs is put in right or 180 degrees off and needs to be turned over ??????? I did scratch a "t" for top on the linkage, but that was sometime ago and how do I know they were even assembled right the prior time? Thank you.
