Re: IH V-8 pickup engines.... How to identify?
Posted by Bob on July 22, 2014 at 15:17:05 from (75.238.1.231):
In Reply to: IH V-8 pickup engines.... How to identify? posted by David Curley on July 22, 2014 at 13:12:43:
On most of them, the displacement is stamped on a machined surface on the RH side of the block, to the rear of the fuel pump and below the point where the cylinder head and block meet.
In he photo below, if you look closely, you can see "V-345A" stamped above the 273272 serial number.
