Re: farmall 300 condenser
Posted by Bob on July 22, 2014 at 17:07:05 from (75.234.23.153):
In Reply to: farmall 300 condenser posted by transtar61 on July 22, 2014 at 15:58:26:
Condensers are TOUGH and rated at 300 or 400 Volts (or more) and a quality one should never/rarely fail.
If they REALLY are failing, he needs to try a different parts source.
Sometimes there's a loose connection or short in the distributor that gets jogged around when parts are changed and spark returns for a while, and the rookie "wrench" blames the condenser or the points, whatever he just changed, only to have the problem soon return.
Looks like there are a number of choices... 2 Prestolite distributors, a couple of Delcos, and an IHC.
FIRST, he needs to identify what he has, to get the correct parts.
