Re: farmall 300 condenser
Posted by Janicholson on July 22, 2014 at 20:10:09 from (74.60.94.18):
In Reply to: farmall 300 condenser posted by transtar61 on July 22, 2014 at 15:58:26:
Condensers are not going to go bed from any battery voltage applied. They appear as an electrical "spring" absorbing and re sending voltage as the points open to limit arcing and to provide a "quieted" circuit for the points to close into. If you have not watched the trace on an ocilliscope showing the primary voltage signal, it is an education. The most common real issues with condensers is old age (like 25 years) or physical damage or heat. The heat is not generated in the condenser, they do not get hot from electricity. So what is likely happening is that the coil is wrong for the applied and the points are failing. when it quits, the condenser is blamed and replaced for no reason. Jim
