Re: Re: How Do I turn my flat bed into a dump bed
Posted by F14 on December 30, 2000 at 07:40:51 from (216.252.28.77):
In Reply to: Re: How Do I turn my flat bed into a dump bed posted by T_Bone on December 30, 2000 at 05:53:08:
I put a Northern kit under the box on my Chevy tonner. I've had it for several years, no complaints. Good quality, easy install, works good, lifts good.
I put the hydraulic unit behind the seat instead of on the frame rail as the instructions suggested, that keeps the delicate stuff out of the snow/sand/salt/slop.
After hoisting a couple of heavy (over)loads, I built a subframe to spread the load at the lift point out some.
Only other modification I would recommend is drilling and tapping the pivot points on the scissors for grease fittings.
Post A Followup
: Re: Re: Re: How Do I turn my flat bed into a dump bed
