Re: Adams road grader with Farmall H engine no start problem
Posted by roger hall on July 22, 2014 at 21:55:06 from (74.126.64.42):
In Reply to: Adams road grader with Farmall H engine no start problem posted by old on July 22, 2014 at 19:06:59:
6v coil will overheat with 12v battery--- if you used a jumper -did you bypass the ceramic block-- some 12v coils call for a resister
