Re: ballast resistor/ IH 184
Posted by leeedwin9 on July 22, 2014 at 23:37:41 from (208.103.28.181):
In Reply to: ballast resistor/ IH 184 posted by pilot199 on July 22, 2014 at 12:08:40:
If the engine on my 184 has not been fully warmed up, I often pull the choke lever out slightly just before I engage the electric clutch switch. Otherwise engaging the clutch and starting the mower deck can kill the cold engine. Once the engine is at working temp, killing the engine shouldn't happen.
--Lee
