Re: Water Gauge Lead Replacement Is It Possible
Posted by mkirsch on July 23, 2014 at 05:33:33 from (65.199.189.6):
In Reply to: Water Gauge Lead Replacement Is It Possible posted by Bob on July 22, 2014 at 19:48:16:
Sounds like a pig in a poke to me, but if you're a hardcore DIY type and you absolutely have to save that gauge, it's worth a shot.
In the end, you'll have a gauge with a needle that moves in response to water temperature, if you're lucky. Probably won't be calibrated even close to correct.
Odds are you'll probably screw up a few before you get a working unit.
