Re: Farmall M looking to pull
Posted by BigTone on July 23, 2014 at 09:36:15 from (70.209.130.58):
In Reply to: Farmall M looking to pull posted by kbw on July 22, 2014 at 19:12:23:
Pulling an M in the stock class is much more fun than juicing it up and running it modified. The cost can get crazy high if you begin modifying the tractor. Like Jim mentioned, replace everything with 450 parts (manifold, head, carb, cam), rebuild motor with step head pistons, remove air intake and replace with a k&n filter straight pipe, get timing correct, valve job, clean gas. You can take your question to the external_link on this sit and the folks over there can help also, but, I'd think hard about the stock vs. modified, I have much more fun with the stock tractor, adjusting weight position, tuning things just right, ect.... Just a better time finding out who has the better tractor that day and busting balls with the boys. For us it's about enjoying the history and hobby of antique tractors, not about how much you can spend on tractor parts. Best of luck and most importantly, have fun! ~Anthony
