Re: 460 over heat issue
Posted by Charlieu on July 23, 2014 at 18:54:57 from (206.8.2.253):
In Reply to: 460 over heat issue posted by Tractordan on July 22, 2014 at 17:32:37:
Here is a simple test that you can do to check for a possible leaking head gasket.
1. Fill radiator to the top with water when the engine is shut down.
2. Install a good radiator cap that fits tight and is air tight.
3. Attach a rubber tube to the lower end of the overflow pipe of the radiator.
4. Hang a clear plastic jug (2 qt or larger) on the side of the tractor with about a qt of water in it.
5. Insert the hose into the water and make sure it stays under water.
6. Start engine and run at 3/4 throttle.
7. Watch for a continous stream of bubbles in the water bottle.
8. This air would be coming from a bad head gasket or a cracked head or crack in sleeve or block.
9. Good luck Charlie
