Owen, I checked & you are right, the tractor now WILL NOT shut off by turning the key.
I didn't notice it at first because I only use the tractor every 10 to 12 days so I turn the gas off until it kills. Our humidity is so high down here & I find this helps minimize carb problems on a sitting tractor.
The new 2 ohm resistor is wired exactly like the old one, which is to say that the lead leaves the resistor & runs down to the positive side of the coil. I believe that is also how the schematic shows it as well.
How can I get this thing to shut off by the key & still charge the battery when running?
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
