Re: farmall h not charging
Posted by soundguy on July 24, 2014 at 12:44:11 from (207.30.46.70):
In Reply to: farmall h not charging posted by sevy1938 on July 24, 2014 at 12:21:47:
static battery is 6.3v charge should be 6.9-7.2 'or so'
have you motor tested your generator?
if it passes a motor test, hook it back up and full field test it.
if still nothing.. bypass cutout.
if it passed motor test and you can full field it and bypass cutout and still nada. double check that wireing that shows charge but none at battery.
i suspect that first!!
