Re: B275 voltage reg
Posted by Bob M on July 25, 2014 at 10:16:48 from (74.67.188.246):
In Reply to: Re: B275 voltage reg posted by Glenn D on July 25, 2014 at 09:46:32:
Glenn - You are correct. As long as a regulator is calibrated for the same nominal system voltage as your tractor - ie. either 6 volts or 12 volts - and is wired correctly, you will be fine.
