Re: How to get Wheel Bolts Loose
Posted by mkirsch on July 25, 2014 at 10:18:08 from (65.199.189.6):
In Reply to: How to get Wheel Bolts Loose posted by PRTZMAN55 on July 25, 2014 at 06:13:40:
The bolts probably won't come loose just spinning the tire up in the air. It needs the weight of the tractor shifting around to break them loose.
Just to be clear, you have the nuts off but the bolts are rusted in place, right?
Rule #1 in these situations: If at first you don't succeed, get a bigger hammer.
Any possibility you can suck the fluid out of the tires before you start knocking them off the tractor?
