Re: How to get Wheel Bolts Loose
Posted by PRTZMAN55 on July 25, 2014 at 11:55:14 from (65.79.254.50):
In Reply to: How to get Wheel Bolts Loose posted by PRTZMAN55 on July 25, 2014 at 06:13:40:
Well not sure tire was flat as flat as it could go so most of the fluid is out , yes the bolts except one are rusted fast to the rim . I tried to use a long punch but they are tight. Also would like to reuse old bolts if possible but if not it out to Hoobers for new bolts or maybe I could use grade 8 bolts and have a head on them these are square headed bolts. Thanks for the suggestions.
Harry
