Re: How to get Wheel Bolts Loose
Posted by rustyfarmall on July 26, 2014 at 06:45:04 from (208.126.186.41):
In Reply to: How to get Wheel Bolts Loose posted by Lmack on July 25, 2014 at 15:48:14:
And what is wrong with a torch?? That is exactly what I had to use when I needed to remove the wheel bolts on my H. Heat the cast iron all around the bolt, let it cool slightly, spray with penetrating oil, and smack it with a hammer. If the bolt doesn't move, repeat the heating process. Don't even try to save the bolts. Get new ones.
