656 Hydro won't move
Posted by Bill in IL on July 26, 2014 at 14:37:45 from (66.94.208.1):
I recently acquired a 656 hydro that won"t move. It was in that condition when I got it.
I have the manuals for the hydro and have been reading and testing. The good is the hydraulics, PTO and steering all work. First thing I changed both hydraulic filters and topped off the fluid. Next I capped the 2 lines going to the control valve and it still would not move. Charge pump pressure at the valve body was 195 psi servo pump pressure was 375 psi. Servo pump pressure was slightly below specs of 390psi.
I have never been into a hydro before so lacking experience here. Any good ideas as what to check next. Thinking next step is going to be checking the relief valves?
