How much have you run it since you did the tune up? These old engines tend to be a little cranky with old gasoline and when not run. Sitting up tends to make them run rough . . . for a while. Hook a load to it and go to work. Every time it starts running rough stop and drain the carb, blow out the fuel line and clean the bowl under the tank. It usually takes about a tank of gasoline to get it going right. (This the way I had to do it every spring back in the day). BTW if you have a rubber hose instead of the steel fuel line that was stock that could be an issue. Rubber fuel lines seem to have loops and will drop below the carb. Air bubbles can get trapped in the loop and cause the engine to run rough even with a clear carb and good fuel.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
