Farmall Regular Clutch Adjustment
Posted by FarmallCT on July 27, 2014 at 05:51:08 from (24.191.226.58):
Hi, I've finally gotten to working on my 1930 Farmall Regular and the problem im having is the three fingers on the clutch are not even with each other which is preventing it from completely disengaging. What i need to know is how do i adjust the fingers and to what specification and do i need a special tool to do it with? I also have the carb and fuel bowl which keep leaking when i turn the gas on. Is it okay to use gasket maker on both the carb and the fuel bowl? If not is there something that would work? Thanks for the help. Matt
