Re: Question for C123- C153 pullers
Posted by pete 23 on July 27, 2014 at 10:36:23 from (74.33.72.212):
In Reply to: Question for C123- C153 pullers posted by Rex Simpkins on July 27, 2014 at 07:55:32:
Your spark advance on the mag is going to be right about 35 degrees before top dead center at all engine speeds and that C-153 is to run about 22 degrees before top dead center at full throttle with battery ign. The automatic advance in the battery ignition unit will, if operating correctly retard and advance the timing according to engine rpm. I would say 35 degrees advanced would cause severe detonation with engine working hard.
You actually need to fine tune it on a dyno for max horsepower with least advance to be safe for heavy pulling but at least get a good battery ign unit made for the C-153.
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
