Farmall A Decals
Posted by Peter Lowen on July 27, 2014 at 13:28:54 from (50.176.32.19):
I have a 1945 Farmall A S/No FAA 125897, which is located in New Zealand. I am living in the USA and obtaining parts for a restoration. Question relates to decals. Should the engine hood decal be IHC McCormick-Deering FARMALL, McCormick-Deering FARMALL or IHC McCormick FARMALL? My research points to the first option. Thanks.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
