I've looked at a few pictures. My Pump guts still in housing appears coupler was removed that drive's pump. It was using a port in bottom to feed live hydraulic pump and 2 return lines on side's. I'm thinking your Idea of pulling the guts make a plate to cover turning pump into just a tank and making a spacer to drop it down is the way to go. I might even be able to drill and tap pump housing for side fittings so I can use the side port hole' s in clutch housing. If not I can go threw top.Thanks for the help.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
