Re: 1940 Farmall H Carb Problems
Posted by D Slater on July 28, 2014 at 07:40:05 from (184.14.185.150):
In Reply to: 1940 Farmall H Carb Problems posted by Pleasejustmakeitrun on July 28, 2014 at 07:21:25:
Packing goes behind the lock nut on the main load screw. Depending on the carburetor it won't give anymore fuel than was required with the screw full open. Or you may still have another problem with, blockage the jets or air leaks.
Unless the distributor springs are ideal and you can get the engine to idle really slow a timing light won't be successful. Set the static time with the engine stopped. Then see if the time advances when the rpms go up with the light.
