Re: 1940 Farmall H Carb Problems
Posted by glennster on July 28, 2014 at 08:04:10 from (162.204.229.223):
In Reply to: 1940 Farmall H Carb Problems posted by Pleasejustmakeitrun on July 28, 2014 at 07:21:25:
to time the engine you need a test light. bring the engine up on the number 1 compression stroke and align the timing marks to tdc, remove the distributor cap and the rotor should be pointing to number one plug wire on the cap. remove the lead from distributor to coil. hook a test lamp up to that lead and connect the other end of the test light to the battery hot. loosen the distributor and rotate the distributor to the point at the light just goes out. that will be timed at tdc. the advance is mechanical so when the engine starts it goes advanced with increased rpm. off hand i guess its around 22 degrees or so full advanced.
