Posted by JRSutton on July 28, 2014 at 15:28:53 from (71.174.108.252):
In Reply to: 1948 super a brakes posted by sony224422 on July 28, 2014 at 09:28:48:
hard to say - but I can tell you the brake mechanism is pretty simple.
adjust the looseness out of the linkage, and if they still don't work - you've got to pull them.
very common to have the seals leak oil into/onto the brakes. especially if the trans is overfilled - which is also just as common.
You need brakes - so rip it apart. You'll find it's a lot of work, but not all THAT bad. Just be very careful with blocking up the tractor - follow the manual's procedures.
if you don't have a manual, get one.
If you get the brakes out and there's plenty left to them and just oily - set them on fire with a torch - burn off all the oil and they'll be fine. Otherwise reline them.
the way the final drives come off might sound a little complicated, but will make perfect sense once you do it. Hard to screw up.
They are heavy - you can use a cherry picker to hold them - but they CAN be done by hand if you don't have a bad back. But I recommend the cherry picker.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
