Re: Need to Free A Stuck Clutch - Janicholson and Others.
Posted by Janicholson on July 28, 2014 at 17:46:45 from (74.60.94.18):
In Reply to: Need to Free A Stuck Clutch - Janicholson and Others. posted by farmallhal on July 28, 2014 at 15:37:38:
I would aim it at open territory so you can get stopped if need be, then using 2nd gear I would start it and going pretty much as fast as it will go, I would apply the brakes to free it. It might take some repeated attempts to jar it loose. To help prevent this you can use a block of wood to hold the clutch down between uses. Jim
