Re: honey bees in gas tank
Posted by old on July 28, 2014 at 18:03:32 from (209.86.226.11):
In Reply to: Re: honey bees in gas tank posted by old diesel on July 28, 2014 at 17:49:00:
Not at all hard to get out. Boil up some water and then pour it in shake it up dump it out. Do that a number of times. Then boil up some ATF and do the same thing and you should be good to go. Bee wax melts at under the boiling point of water so by doing that you will melt it and then be able to pour it out. Then you do the ATF to clean and remove the little bit that the water may not get out
