Re: Need to Free A Stuck Clutch - Janicholson and Others.
Posted by old on July 29, 2014 at 10:36:48 from (209.86.226.57):
In Reply to: Re: Need to Free A Stuck Clutch - Janicholson and Others. posted by Nebraska Cowman on July 29, 2014 at 10:03:34:
The higher the gear the more likely the clutch will tend to slip. You want it to free up so the more stress you can apply the more likely if will free up. Just like when a clutch is going bad you can drive it a long ways as long as you use the lower gears. Like in a car or truck
