Posted by farmallhal on July 29, 2014 at 11:21:29 from (76.2.172.244):
Thanks for all the comments and suggestions to my earlier thread on this problem. Since I had several varying comments about which gear to use I called a retired IH mechanic in the neighborhood for his advice. I was told the reason for using the higher gear is you have less danger of tearing off material from the clutch disc. I blocked the clutch so it would release, put it in 4th gear and rocked it back and forth about 12 or 15 times on the concrete floor before I heard and felt it release. I drove it around for about 30 minutes (mainly because I just like driving the tractor) and parked it back in the tractor building. The tractor now has a custom built clutch block as noted by Janicholson so doubt this will be a recurring problem. Thanks again for all the comments and suggestions to my initial thread, Hal.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
