Re: farmall 300 running a little rich
Posted by wayne in mn on July 29, 2014 at 14:39:49 from (71.8.150.168):
In Reply to: farmall 300 running a little rich posted by bill gaw on July 29, 2014 at 10:08:20:
I would FIRST check that the choke is not partly blocking the airway and that the air cleaner is not restricting air flow.
Isn't there a high speed mixture screw on the bottom of the carb you can adjust?
Run the engine wide open and turn the screw in a little at a time until the richness goes away.
