Re: farmall 300 running a little rich
Posted by Janicholson on July 29, 2014 at 19:01:07 from (74.60.94.18):
In Reply to: farmall 300 running a little rich posted by bill gaw on July 29, 2014 at 10:08:20:
The mixture screw (bottom front of carb bowl) adjusts the load richness. It is not the main jet, it is a method of fine tuning the richness to meet demand at full load if working the tractor at near full power, and leaning it when using light loads. It can be adjusted in to make it lean enough to stumble when opened up, and rich enough to make it burn with a bit of black is worked hard. It should be played with a quarter turn at a time with the engine warmed up so that it just shows a very tiny bit of dark smoke when pulling at max HP/torque. If you are not working the tractor, it can be leaned so the exhaust is clean, but still goes from idle to full speed with no stumble. Jim
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
